I should be getting more boost? Right?
K so with my 01 6 spd with the juice with attitude I'm only buildin 24-26 psi with a boost elbow during wot! and thats on level 5 .... and I used to have the K&N cold air intake ( before I found out how bad they are on a cummins ) with hard plastic pipe and everything and it didnt change my boost either... and I've talked to guys with the same year truck with a 6 spd and there buildin between 32-34 psi with a stock turbo and chip!!!!! whats my problem? any help/advise is much appreciated
Do you have a boost elbow on your stock charger? It's a 90* brass fitting with 1/8 pt and a barb fitting on the other end. Should have came with your Juice I would guess.
something weird is going on...these are the same two posts within minutes of themselves from last night, but the one just showed up this morning?? (its not a fault of you, though.)
https://www.dieseltruckresource.com/...d.php?t=170049
DISTURBED
09-19-2007 09:20 PM
MikeThomas
02-17-2007 10:19 AM
getblown5.9
22
10-18-2006 12:36 AM
carsonhw
09-24-2005 07:58 PM
mr T
09-11-2005 01:37 AM
