I should be getting more boost? Right?
K so with my 01 6 spd with the juice with attitude I'm only buildin 24-26 psi with a boost elbow during wot! and thats on level 5 .... and I used to have the K&N cold air intake ( before I found out how bad they are on a cummins ) with hard plastic pipe and everything and it didnt change my boost either... and I've talked to guys with the same year truck with a 6 spd and there buildin between 32-34 psi!!!!! whats my problem? any help/advise is much appreciated
have you adjusted your boost elbow?
is your wire tapped well? sometimes the supplied connector doesnt work too well.
if youre concerned about a boost leak, pressurize the system and try to find the leak.
what kind of elevation are you at? when i used to live at 5200' i had a hard time getting the same boost others were seeing 'down below'.
every truck is a little different...if you dont have boost leaks, youve played around with the boost elbow, your wire is tapped well, and your EGTs are in check then dont worry about it.
DISTURBED
09-20-2007 09:41 AM
MikeThomas
02-17-2007 10:19 AM
getblown5.9
22
10-18-2006 12:36 AM
carsonhw
09-24-2005 07:58 PM
mr T
09-11-2005 01:37 AM
