I need a turbo...
Old 05-02-2005 | 08:58 PM
CTD99's Avatar
I need a turbo...
So my engine is dead...
https://www.dieseltruckresource.com/...5&pagenumber=2
Found out today that pieces of the #6 piston managed to take out the turbo as well!
So... I need some suggestions for a replacement. Money is a factor considering the thousands of dollars the rebuild is going to cost me. I will be rebuilding the engine to the config in my sig (with the exception of a 4" exhaust) but I imagine there is a better alternative to just a plain old HX35.
Also, I'd like a turbo that will support the additional power when the day comes that I decide to tap the pump wire.
Thanks,
Russ
Old 05-02-2005 | 10:01 PM
WildBill's Avatar
Have you tried to find a good used engine from a wrecking yard? might save big time. What HP will you be at with wire tapped? That might help figure out what turbo you will need.
Old 05-02-2005 | 10:16 PM
CTD99's Avatar
"Good" used engines are hard to come by... no luck so far.
I guess-timate that I'd be in the ballpark of 350 rwhp with the wire tapped, but I can't say for sure... Never got the chance to dyno.
Old 05-03-2005 | 12:32 AM
halerazor's Avatar
b1,hx-55 or one of htt's turbo's
Old 05-03-2005 | 01:12 PM
PowerstrokeThis's Avatar
I have a HX55 I need to get rid of
Old 05-03-2005 | 02:24 PM
duke1n's Avatar
I have a nearly new B1-2(2700 miles) I need to get rid of too. I also have some even newer Mach4s(1200 miles) that work perfect with this turbo
PM me if interested
CumminsRedneck
07-06-2013 04:20 PM
captntim
12-26-2008 03:53 PM
smokin24v
03-18-2008 02:21 AM
Ada381
02-10-2008 08:58 AM
redram
12-10-2002 10:54 AM
