i,m putting in dd2 injectors today need info.
box i got did not come with any instructions??? any tips...i know i need a inch pound tourqe wrench..any tips apreciated...brad
bws,
I have a .pdf file with the instructions from Diesel Dynamics for injector install.
If you have an email address, pm me and I can send it to that.
~Rob
~Rob
My injector experience:
1)19mm Stubby wrench is perfect for injection line nuts-- you can't overtighten them
2) Loosen the clamps that hold the lines to the engine, not to each other (the DD instructions you received show which ones to loosen)
3) DO NOT OVERTIGHTEN the injector retaining bar screws (the little 8mm ones). Those screws will break. Tq spec is in INCH pounds. A stubby ratchet works good for these.
4) When you are buttoning it back up, snug the injector retainers and the injection line nuts alternately. You want your final snug to be the inj line nuts (19mm)
5) Work slowly and methodically. You can take off the lifting eye at the back of the engine and leave it off (throw it in your toolbox and thread the bolts back into the engine).
6) Start at the back, doing the hardest parts first and leave the easier parts till last. That way, as you get tired and frustrated, the toughest parts are behind you.
jmho
jmho
all done...started rough and smoked for a few minutes then smoothed out.it was a easy job.my tourqe wrench didnt make the ups delivery today but i know 28inch pound pretty well.i work on a/p's.i,ll pull the valve cover and retourqe the injector retainers[and do a valve adjustment at the same time]...injectors are easy...the hardest part is getting all those blue tube supports off..whats the tourqe.instructions? says 28" pounds on the plates and like 75 foot pounds on the injector[19mm]nuts...sound right???dont like that tst grabber probably should have soldered the comp wire...feels like the clutch will slip in 3rd now.....thank for the help guys...ps the old injectors are real dirty,i will always run cleaner now...
Rattletrap1
12-10-2004 09:58 AM
Cummnzpowr
32
04-07-2004 03:42 PM
