i cannot make up my mind!!!
i cannot make up my mind!!! (on a turbo)
i am looking to get a turbo. i am thinking about htt's 62/12, but then im starting to think about the 62/14 to cool my setup better? what would yall suggest? or a sps62/12 62/14 or ps62/12 62/14 what would you suggest out of these or even a completely different turbo and is there much of a difference between the phat shaft and htt's turbos. thanks for any help or advice.
(check out sig for mods)
by the way i have 4.10 gears and going to be going to a 33 inch tall tire soon
62/12 will spool very fast with higher top end egts! The 62/14 will spool a touch slower but not enough to write home about and give you a little more top end! The HTT and Industrial turbos are similar and both are great products, the SPS series is said to move more air than the PS Series , As well as moving more air there said to offer less surge and somewhat equal spool up ! The HTT 72 Series line is a great turbo and moves alot of air as well and cools very well! I would look at a 62/14 in the SPS or 72 Series that will give you room to grow, If your going bigger look at a 64/12!
I run a sps 66 and make a touch over 595 on fuel only!
Hope this helps!
Hope this helps!
ds1rider
03-22-2005 11:07 AM
Journier
11-02-2004 02:04 AM
