hybrid turbo question
Old 07-31-2009, 03:56 AM
cumminsdriver635's Avatar
I hope you didnt order one of those chinese HX35's off of ebay for cheap?
Eric
Old 07-31-2009, 05:18 AM
rootremblay's Avatar
I think you'll be happy with the HX-35 Dodgenit, it's a versatile little charger. The hot side of the HX is a little small but your head breath better than my 12 valve so you should be fine. I think you'll notice a nice gain in power, once you get used to the lag it's just another thing. plus you can always swap housings ect... easily and there is a ton of parts and info to do so, which Im sure you know already. have fun with it.
Old 08-02-2009, 05:44 PM
DodgenIt's Avatar
Thanks rootremblay I think I will be havin fun with it for sure .
Cummins drvr, no not a cheep China one. Its a Holset from a shop in Idaho If I remember location right. Brand new with warrenty, and a 98% approval rating over the last year. I made sure all was good way before clickin next.
Im confident I think it will be just what I need right now.
Old 08-02-2009, 08:20 PM
You should be in good shape then. Let us know how you like it!
Eric
Old 08-03-2009, 04:20 PM
DodgenIt's Avatar
I will for sure! Looking forward to it
One other thing.. Does a new turbo need a break in period? It should be arriving this week and Im dragin friday night. I'd love to get it in befor then, but not if I might damage it throwing it in and mashin it with extra fuel a day later.
Old 08-03-2009, 04:37 PM
No real break in period. Just run some oil through it before you start it. Then drive it several miles easy, and basically once it has been on long enough to get everything oiled real good, let the fun begin. Id say 5 or 10 miles should have it lubed plenty good enough to let it eat.
Eric
Old 08-03-2009, 09:49 PM
DodgenIt's Avatar
To get oil runnin through it befor start I just bump it a few times dont I? Crank it and let it turn a bit but not full start?
Old 08-03-2009, 11:06 PM
No, your motor wont build oil pressure until it has ran for a couple seconds. Just take a jug of oil and pour some into the turbo while you spin the shaft. It just helps to keep it lubed for the first start.
Eric
Old 08-04-2009, 07:13 AM
DodgenIt's Avatar
Pour it into where the oil line goes right?
Do I need to worry about getting air in the oil line while its off and having to bleed it?
Or is that partly what pouring in the extra oil is for?
Old 08-04-2009, 01:29 PM
Yep, just pour some into the oil inlet and it will help lube it some. No need to worry about bleeding anything.
Old 08-04-2009, 08:53 PM
DodgenIt's Avatar
Awesome! Should be here thursday and will be in by monday. Thanks Cumminsdrvr. Im sure you all will hear how much I love the extra air in posts soon to come.
Ian
Old 08-04-2009, 10:07 PM
I just bought an 05 3rd gen turbo for mine. Im anxious to see how it does. Just gotta order some parts so i can install it and then ill be good to go.
Eric
Old 08-06-2009, 06:48 PM
DodgenIt's Avatar
Is that gonna replace your HX-40/16?
My brothers seems laggy to me, Im sure there will be a major differance between his 05 and your 12v. Let us know how it goes!
Old 08-07-2009, 12:01 AM
Yep, its gonna take place of the HX40. I cant pull work stock with an HX40 because it wasnt an original dodge/cummins turbo out of a 1ton or smaller truck.
The HE351cw should spool a good bit better than the HX40, and flow more air. I think ill be happy with it. Ill post up a writeup when i get it done.
Eric
smokeblack
10-20-2006 08:33 AM
vagabonddreamer
09-09-2006 08:38 PM
Tartarus
0
10-25-2003 11:55 PM
Tartarus
10-22-2003 03:53 PM
mcevins
20
03-18-2003 09:38 PM
Quick Reply: hybrid turbo question
