Hybrid Boost Controller
As stated above..boost doesn't make power in diesels...fuel does. In EFI gassers, the 'puter adds gas if you add air.
Higher boost may help your EGT's drop a bit, but you'll need fuel from somewhere for any appreciable power gain.
It does seem a likely candidate to replace a boost elbow IMHO. Many gassers use fish tank valves as "bleeders" to lessen the signal to the wastegate. This method is known to have spikes that can detrimental (detonation, blown headgaskets, blown IC boots, etc.).
What they said. It's an adjustable wastegate controller. If you want quicker spool up you need more fuel at low boost. You need to loosen up your star wheel setting, that will get the extra fuel to com on sooner and help with spool up.
Dusty Ratcliff
08-20-2006 08:42 AM
northslope
07-05-2005 11:38 AM
Captain Insane-O
01-11-2004 03:08 PM
atc250r
05-23-2003 07:36 PM
