HY 35 steel waist-gate line
why not just turnbuckle the waste gate you will have the same effect but the hy is just about maxed out at 20psi any way any thing over that is hot air ditch the hy asap as I am trying to do also
Put a turnbuckle on the wastegate and lock it shut. With more fuel you can get about 32 to 34 psi out of the HY.........and that is max. They came from the factory gated at 20psi but they are good up to the 32-34......after that is when it's making / producing only hot air....not the 20psi as Taken stated above.
~Nick
~Nick
I did quite a bit of testing when I had an HY-35, and agree with Nick.
I found up to 30-32 psi I was still inside the efficiency MAP and still reading 'compression' pressure. Above that boost gauge shows more 'expansion' pressure than anything else (from heat buildup), and makes no more HP/TQ.
30 psi would be a good, conservative boost level to insure max cooling and performance.
RJ
I removed the canister and stuffed a 22 shell in the line and reassembled, good to go after that. Had to wrinkle the end of the shell just a bit to get it started in the tube.
However your HY is junk and you need to send it to me ASAP, order a new fancy turbo from HTT and be done.
Seriously I need a HY for my Toy so hurry up!
dan
dan
Thanks for the tips. I thought that plugging the line would be easier then trying to wedge a turnbuckle into that tight area. I will need trans. upgrades before adding any more power. So I will keep the HY for now.
lenuelmp23
12-28-2011 01:47 AM
