hx40 power
hx40 power
I was just wondering how much power a hx40 is good for I wana get atleast 500 out of my truck and wanted to know if a hx40 would be good. also how reliable it would be. What kind of boost psi would I see from this turbo I think I am pushin my hy35 to far and don't wana have it come apart.
The Guru
Which 40 do you have? You need to decribe the size of the inducer and # of blades on the impeller. I haven't used one in years, but I think that the hi flow impeller is seven blade and its 61mm inducer. What's the size of turbine housing and its is a T-03? You own the turbo, or just looking for a cheap upgrade?
There has been trucks run 500rwhp on a HX-40, but they might break. They have a habit of snapping shafts, as the shaft is to small diameter for the weight of the compressor impeller/turbine, during a stall/surge the shaft will break. So be careful. Lots of guys run them earlier on, today the S300 or garrett are more available and work better. Don't get me wrong I have over 100k on a HX-40/BTH-3B twin combos, so they work.
The Guru
How much fuel you have available? You should be able to re-torque the head bolts to 125 ft*lbs. I would limit the truck to 40-45psi and keep the egt's below 1300deg's. I run ARP's standard and standard non-oring head. So far I've run up close to 50psi.
As for bullet proof, who knows, head gasket just go sometimes, even in stock trucks.
If you re-torque the head, do a valve re-lash. 10 thou on intake and 20 on exhaust. some do it tighter. The tighter you go on the exhaust, less clanky noise you get, but you risk a not seating the valve.
I have a edge juice and a bully dog big fuel kit. The edge has the hot code but I want to get a smarty annd stack it on the edge and 100hp injectors.
Txwelder
14
11-11-2007 04:28 PM
Hawkeye
09-23-2003 08:22 PM
