HX35/Super 40 Hybrid Turbo
The upgrade inlet wheel and housing I ordered for my HX35 is the new 7 blade Super 40 style. The wheel is 4035879 and the housing is 4039617. I haven't installed the turbo yet, I plan on installing a 3k gov kit, larger DVs, and a 100 plate. Will this be enough turbo for my combination?
It will but in time it will wear! I would recomend if you plan for more fueling go with a 62/12 or a 64/12 , Your current combo will be HOT! I dont see it supporting the DV's
I am now running a WH1C that tops out at 30psi and my EGTs are controllable. Not a lot of smoke until I hammer it. I had a stock 2001 Dodge Cummins and the truck feels like a rocket compared to it. I am not sure what size my exhaust housing is but I plan on using it on the hybrid. My engine is a non-Dodge and the exhaust manifold and exhaust housing are different from the Dodge style. I will check out the 62/12 and 64/12 turbos.
PourinDiesel
05-01-2006 06:15 PM
Captain Insane-O
01-11-2004 03:08 PM
ridofpwrstroke
08-25-2003 07:44 PM
