hx35 1/4 times
Old 07-10-2007 | 07:39 PM
1998dodge's Avatar
hx35 1/4 times
how fast can you go on a stock hx35? 1/4 time and mods.
Old 07-10-2007 | 07:44 PM
Mike D's Avatar
12's................... I guy named Matt forgot his last name, has done it with is 12 valve.
Old 07-10-2007 | 07:55 PM
OrangeCounty12V's Avatar
Wow! what's the secret. I'd like to hit 12's or even just 13's with the hx35
Old 07-10-2007 | 07:56 PM
cumminsdriver635's Avatar
I want to at least be running 13's on mine before I am done with it Should be mid 14's how it sits.
Eric
Old 07-10-2007 | 08:02 PM
Mike D's Avatar
Total disregard for EGTs!
Old 07-10-2007 | 08:07 PM
Mike D's Avatar
http://mydhra.com/home.php?member=turbomatt
Here is Matt's dhra page. He's not running the 35 anymore, but he should be able to answer some questions for you.
Old 07-10-2007 | 08:13 PM
rockjeep73's Avatar
I ran as quick as 13.40's with my hx35, this was also with stock injectors. With some bigger sticks I could have easily gotten the truck in the 12's.
Old 07-10-2007 | 08:21 PM
JPM's Avatar
JPM
Help
My truck runs OK but its not in the 13's.
Super 40 with 370's 3k gsk 45lbs of boost alot of smoke so I know its getting fuel. but I still don't think its fast. Help
Old 07-10-2007 | 08:25 PM
Mike D's Avatar
Whoa! Did you say you ran a 13.4 with a stock turbo and stock injectors? Number #2 only?
Old 07-10-2007 | 08:30 PM
rockjeep73's Avatar
Plus water/meth. Snow stage 2. 50/50 mix.
Old 07-10-2007 | 08:43 PM
Mike D's Avatar
That's impressive, rockjeep73. Have you ever dyno'd the combo?
Old 07-10-2007 | 09:51 PM
rockjeep73's Avatar
The 1st time I ever had my truck on a dyno it did 351hp on a mustang, the same day I went to the track and ran 13.90's.
The next time I was on a dyno it did something around 415 on a dynojet, that was with the setup that ran 13.40's.
Old 07-10-2007 | 10:35 PM
Jturs's Avatar
so your truck was pretty much completly stock besides water/meth and snow stage 2? did you have a box? how much does it cost to do that? i would love to put my truck in the 13's.
Old 07-10-2007 | 11:03 PM
rockjeep73's Avatar
No, it wasnt stock. When I was running 13.90's it had a Scotty 2 intake, 4" exhaust, TST Comp, Edge EZ, Snow stage 2 Water/Meth, and an I.I. HRVP44. That is the setup that did 351HP on a mustang.
When the truck was running in the mid 13's it was the same setup plus, a ported stock exhaust housing on the turbo with enlarged wastegate (in order to keep the boost down), Ported head (done by me), .020" thicker head gasket, and F1 valve springs, ARP studs, and O-rings all done while the head was off. This setup is when the truck did about 415 on a dynojet.
Obviously not all of these upgrades are necessary for running 13's, they are however necessary for the level my truck is at now.
A key component that I almost forgot to mention was the full DTT trans and converter.
Old 07-10-2007 | 11:08 PM
1998dodge's Avatar
thanks for all the help
