Hx vs Hy Turbo's
Old 07-17-2004 | 04:01 PM
MLR1's Avatar
Originally posted by stonewalldiesel
Thanks, MLR1 i was mixed up with this issue, so which is a better turbo???What type of turbo is on the 98.5 24V?? The reason is that a friend of mine has one laying around and I was wondering if it would be worth the effort.
It won't do you any good because they are the same turbo. BigBlue & 3KrackerRacing are both right they didn't start using the HY until 2000 on the autos (forgot to mention that).
Old 07-18-2004 | 11:32 AM
13FOX's Avatar
The HX35 will handle a max of 485hp with no egt issues as long as boost is not pushed past 34lbs.
Old 07-18-2004 | 12:30 PM
SjLingenfelter's Avatar
485hp? How did that manage to happen?
Old 07-18-2004 | 02:41 PM
BigBlue's Avatar
I'm curious to.
Old 07-18-2004 | 04:07 PM
duke1n's Avatar
Well **** looks like I will be good with my hx35. Seriously, I just put some mach2s in with my comp box. Will be curious to see what happens with EGTs.
Old 07-18-2004 | 06:05 PM
stonewalldiesel's Avatar
Thanks for all the great info guys, I'm still very new to this bombing thing but man it is addicting. Need very large wallet .
Old 07-18-2004 | 06:34 PM
phox_mulder's Avatar
Maybe, if you don't tow anything.
I'm hoping my HY will handle the 450ish HP I'm going for eventually.
Don't tow anything, just daily driver, offroad explorer.
phox
Old 07-18-2004 | 10:13 PM
But I though that the Hx35 and even the Hy35 will handle hp up to 350-400. I havent heard of anyone going 485hp with single hx35 or hy35. Maybe im wrong and need to look around.
Old 07-18-2004 | 10:51 PM
ramtd02's Avatar
Like they said above...the HX and HY WILL handle this power...given boost is not in the 36+ PSI range. However....this is only accomplished with regular drivers....any towing or racing up hills and the EGT's will shoot through the roof. It is much safer to get a HX40 or B1 if you surpass the 420 bhp mark and want to pull anything. Just too be safe
Old 07-19-2004 | 10:51 AM
13FOX's Avatar
Check out this web page.
http://www.dieselram.com/reviews/properorder.htm
Ted Jannetty of Jannetty Racing did a review on upgrading the ISB engines. This is a great way to look at how to properly bomb your ctd. Enjoy the reading.
Old 07-19-2004 | 11:05 AM
gunracer1's Avatar
a hx 35 will not support 485 hp without egt issues. you can get the hp out of one but it will get hot quick. i have 430 hp with the stock hx35 with a 14cm exhaust housing, and it will bury the pyro at will. i can tow just fine but it would be killer with some more air.
Old 07-19-2004 | 12:33 PM
Originally posted by gunracer1
a hx 35 will not support 485 hp without egt issues. you can get the hp out of one but it will get hot quick. .
Thats what i thought but wasnt sure.
Ada381
02-10-2008 08:58 AM
j
01-09-2004 09:19 AM
Haulin_in_Dixie
07-21-2003 12:14 PM
redram
12-10-2002 10:54 AM
