hx-36 htt 62/71 14cm twins?
You're not going to feed anything with an HX35, which is your small factory turbo.
To keep a turbo fed, you have to use one that is 2-3 times larger (in terms of flow) than the small one. The HTT is bigger than the HX35, so the HX35 would possibly damage the HTT by starving it for air and drastically increasing the thrust load on the turbo.
Try something more like an HT3b for your HTT.
JMO
JMO
dodgediesel
17
04-05-2011 11:21 AM
Bobcat698
11-08-2006 11:20 AM
Stock 02
28
09-24-2006 11:09 AM
