hx-35w/hx-55w in a twin
Originally Posted by singleturnout
will a hx-35w work with a hx-55w in a twin setup and what mods would need to be done
An HX55 is too small to be used as a big charger in a twins set. Most people use a hybrid version (HX40-HX55) and run them as singles.
JMHO,
Chris
IMO, a 55 is too small to go with a '35. Try to find an HX60 or HT60.
jmo
If your serious about doing this, buy a big brother turbo for your primary and use your HX50 for the secondary. It would spool like a dog, but man think about beautiful inlets on those bad girls. Two girls are better than one. Then you'll need some heavy fueling and most definately a wild P pump. It would be one bad bikini rider.
Thanks I Will Look Into A Hx-40/hx-55 :d
BTW is JR's lil 55 aka baby 55 a 40/55 hybrid?
An hx35/hx55 would work. I tried an hx35 over Master Power GT45 and it spooled up really fast. Towed well, ran cool. The problem was it flattened out power wise at about 2300 rpm. Probably a 450-475 hp practical limit before egt would start becoming an issue. A new hx55 will cost double what a 3b costs.
jrussell
06-22-2006 02:29 PM
