Htt Stage Iii Hx35 Upgrade
Old 12-15-2004 | 09:52 AM
bwat4's Avatar
Just installed HTT STAGE III UPGRADE COMPRESSOR HOUSING AND 60mm High Flow WHEEL.
Pulled the turbo Monday, drove down to Utah Tuesday to have it upgraded, reinstalled it the same day. First observations are that it dropped the EGT by 200+*, smoke was reduced significantly even when I try to turn off the daylight. Turbo whine is much more pronounced.
With the setup before the hx35/40 updrade the EGT would get up to 1450* on a hard pull in the summer forcing me to back out of it. That shouldn't be a problem now.
Anyone care to guess what HP this will be putting to the ground now?
Previous dyno run was with stock airbox and regular hx35.
Old 12-15-2004 | 10:24 AM
CTD_Neil's Avatar
Sounds like a good turbo you got there. What size injectors are those EDM's?
Old 12-15-2004 | 10:30 AM
bwat4's Avatar
DonM's 1.5 EDM's. Only supposed to be 85 HP but I think they put out over 100 hp.
Brad
Old 12-15-2004 | 06:08 PM
gwhammy's Avatar
That turbo with you're combination sure does give you the everytime ya drive it. It's almost the same combo I had except I got 2.5's. I almost liked the dd2's more as you could pull anything and not get over 1200. I put that turbo on my 97 and it's pushing 45 lb., sure hope it doesn't before I stack it.
rlyons
01-05-2007 05:36 PM
bhoff1175
09-04-2006 01:06 AM
acook
04-14-2006 02:10 PM
stillsmokin
09-29-2005 10:36 AM
