HTT Sledpuller 66 HTB2/66
Muted User
Does anyone run this turbo? Does it have good streetability? we have to get a bigger turbo becuase our HX-40 is out of its effciency range with the power we got. I think so far this is a better turbo. is there any other kind of turbo that may be better other than twins, too much work and money.
Thanks
Cody
Thanks
Cody
So when you are looking at it, what are you looking for? What size exhaust housing do you have on your b2? What sort of boost and EGTs did you see at that HP number in your sig? I've been waiting on B1 Steroid for awhile and would consider one of the 66s if I could get a hold of someone that could offer some technical facts and not just a sales pitch about how well it works on their CR trucks... sigh.
How about drive pressures at 45psi? Can't seem to find anyone including the makers of both 66s, that can answer that question. If I was making/selling a turbo, I would be able to provide that info
On my truck pressure ratio is 1:1 at 45psi of boost. On the dyno it made those numbers at 42psi which is as high as I could get it, egt's topped at 1400. My b2 has the 14cm housing which is actually closer to 15, but, thats what htt calls it.
napa 600
02-23-2006 11:12 AM
napa 600
02-01-2006 06:14 PM
CTD_Neil
16
07-19-2005 10:47 AM
