HTT Manifolds VS ATS Manifolds
I'd like to know also, since I still need a new manifold. Also do they help with egt's at all? Or do they need to be ported or port matched or both to help out with cooler egt's? If so, who will port one and then ship it to you?
I have heard that the finish of the HTT manifold is nicer other than that they are about the same. Also for them to really flow anymore or decrease egt's you need to port them more than the way they come. The biggest advantage to them over a stocker is that they won't crack. If your looking for a huge performace gain your money is better spent elsewhere.
My exhaust manifold gaskets are shot.. I was told that if I take the manifold off I may not be able to get it back on due to shrinkage, and it already shows signs of it, just hasn't cracked yet.
Originally Posted by ATSDiesel
. The manifold has an option...... a bigfoot flange for large turbos.
RJ
Originally Posted by Dave88LX
What causes stockers to crack?
At least that's my understanding of it. I've hit as high as 1800* and my stocker isn't cracked yet.
Saw this in your website with no statement of the advantage. The benefit to me of the "bigfoot" Flange is...??
RJ
The only thing I could think they mean is for a larger turbo flange like the pro 52 has.
RJ
My HTT came assembled and with pyro ports. I don't get the whole porting deal. The HTT matched exactly. Even the gaskets were an exact fit. I don't think it did jack for spool up EGTs but it looks pretty and won't crack. I did have to re-route the heater core hose as the stock metal tubing would not work with the HTT manifold.
