HTB2 good for me?
HTB2 good for me?
Trying to find a good matched turbo for my application I will be towing often not more than 10k lbs. on most occations but do get heavier than that maybe 4 or 5 times a year. The truck is a p-pumped 175hp first gen with 4.10 gears and getrag 5spd with a 10 plate, soft AFC spring, 3k gsk but adjusted to fuel to 3500, 60lb valve springs, and soon to come 191 delivery valves and 330 injectors. I am currently leaning towards the HTB2 street stock 62mm with the stainless steel 13cm2 exhaust housing. Any suggestions is greatly appreciated thanks.
Not sure how hot it gets yet cause haven't drove it since the conversion but hoping to drive it this week some time and I'm setting the timing at 17.5 degrees and delivery valves are probably going in before I drive it too so I know it will be toasty for sure because currently I have a HX35 with a 16cm2 exhaust housing. But I need a turbo that is good for daily driving and one that spools good for towing so I can tow without constantly worrying if the pyro needle is buried.
Well I finally got it running and drove it and love the conversion and I hit right at bout 1200-1300 degrees wot at 40lbs of boost and I know soon as I get 191dv's and set of injectors that turbo won't cool anything so need suggestions on turbo set.
CTD_Neil
16
07-19-2005 10:47 AM
