Ht4c?
Ht4c?
Has anyone ever used one or seen one in a twin turbo setup? I think it has either a 26cm or 27cm (somethin' like that) turbine housing. What would a good charger to compound it with? Would it be a decent primary in a daily driver/ drag racing setup? I'm mostly just thinking outloud but any info would be appreciated!!
it is big, way big for a daily driver set up. way to big to run a single. unless you want it to start spooling at 4k or so. but if you want a big set of twins that will make a bunch a boost, stick a 66mm or so turbo above it.
GO 4LO
08-25-2004 10:11 AM
