Hrvp44ip
Old 09-27-2005 | 09:00 AM
G-NOTE's Avatar
Question Hrvp44ip
Is it true that just installing this IP,
http://www.industrialinjection.com/m...odge+Fuel+Pump
the performance increase's...
I heard people saying that they removed the comp box becuase the IP was as good as a box on 5x5 ?????
Is this true???
Old 09-27-2005 | 09:06 AM
blackdiesel's Avatar
Registered
it says "Super High Output Gain up to 60 to 100hp" if the specs are right, it wouldnt be as good as a 5x5 comp. but if i would have known, i would have installed that one insead of the stock type i replaced my old one with.
Old 09-27-2005 | 10:00 AM
RowJ's Avatar
Reports I've read say as good on the low end as 5x5...but will it flow any more fuel on the top end than a standard VP44?
RJ
Old 09-27-2005 | 03:24 PM
G-NOTE's Avatar
Smile
I just put another factory replacement on my truck, some more "DEALER JUNK",but I know a junkyard near by my house that has a 5.9 cummins that they told me $50 for the fuel pump....
Fuel Pump...OK if you say so....
Since they don't know, I'm not going to tell them...
I'm going to get it and use it as a core. So that I can get the HOT ROD VP44IP...And still keep my factory junk, just in case!!!
Old 09-27-2005 | 03:55 PM
RowJ's Avatar
Bet they are talking a Lift Pump.....those guys can't be that stupid.
Old 09-27-2005 | 03:57 PM
Bocifus's Avatar
Make sure you are getting the injection pump for $50 and not the lift (transfer) pump, cuz you won't be able to use the lift pump for a core on the HRVP. $50 sounds like the lift pump.
l8er,
Casey
Old 09-27-2005 | 04:18 PM
G-NOTE's Avatar
Thumbs up
I'm hispanic so I can say this...The place is called TEX-MEX auto parts...
And YES they're that stupid, he pointed a the IP and said the thing that all the lines go into????
I said, Yup thats it...
He said $50, NO WARRANTY!!!
I said Ok, pull it and I'll pick it up tommorrow!!!
Old 09-27-2005 | 04:38 PM
Bocifus's Avatar
And No they're that stupid, he pointed a the IP and said the thing that all the lines go into????
BIG time score.
Good deal.
Casey
Old 09-27-2005 | 04:46 PM
chevota01's Avatar
The pump put out more fuel than my twins could clean up. Makes alot more horsepower and delivers alot more fuel throughout the RPM range.
Old 09-27-2005 | 05:56 PM
G-NOTE's Avatar
Question
So if I find more like that should I buy them...
Who will buy the cores????
Old 09-27-2005 | 06:03 PM
BigBlue's Avatar
If you can find a core for $50, I'll buy one from ya for sure.
Old 09-27-2005 | 06:04 PM
1ST GEN.'s Avatar
Does the pump only add that 65-100 HP without a box ,or will it actually add that much on top of a box, I've heard most hybrid pumps add 40 hp but turn a box on an it adds as much fuel as a stock pump
Old 09-27-2005 | 08:52 PM
chevota01's Avatar
The pump itself is capable of 65+ horsepower. I swapped out my injectors from Mach 4 to DDIIs and there was no difference in performance - it was all from the pump. The fuel box made very little difference - drag comp. This may not be the case for everbody, just my experience.
Old 09-28-2005 | 08:41 AM
G-NOTE's Avatar
Red face
From what I was told just adding this pump was huge, when you start adding boxes with tap wire you neutralize the pumps added horsepower, but with a superchip or mad ecm its a good combo!!!
I'm not sure on adding injectors, and the pump...
But my guess would be good except I'm sure EGT's would go through the roof, this would probibly be good with an aftermarket turbo and good exhuast, but I don't know about the smoke!!!
Old 09-28-2005 | 09:11 AM
CTD NUT's Avatar
I don't see how a fueling box will hurt power on a HRVP.....the HRVP is set up to simply flow more fuel but still runs off the fueling/timing maps from the ECM to control actual fueling and duration.....A Comp is a piggy back box that simply builds more advance and duration on top of the original maps.....this arrangement on top of a IP that simply flows more fuel than a stocker should be only capable of just making even more hp than a stock IP with a box. It is easy to see that the best compliment to an IP that flows more fuel would be a set of sticks that also flow more fuel!
