Hp and Torque Question
Old 12-15-2009 | 07:07 PM
oleblue61's Avatar
I am in the market for a replacement clutch before anyone gets started with brand wars I am supposedly replaceing a sb con o (had a *********** mechanic moonlighting supply and install think he screwed me), another diesel "junkie" told me I had too much power for an "o" , my sig might not show still so real quick I have an 02 2500 nv4500, edge ez, factory eth injection pump, 4" mbrp, BHAF, boost elbow. I am just really curious about ball park estimations.
I do tow bobcats and occasional boomlifts
Old 12-15-2009 | 07:19 PM
Jaxn51's Avatar
Sounds like folks are blowing smoke........................
I have an SB clutch and tow 14k with it. My entry to the street is a sharp left uphill......steep uphill. The clutch is flawless. Unless you're planning on boosted 3rd gear launches or some other such shenanigans, a Con O or OFE will be more than adequate. It will also give you some room to grow, should you care to.
Old 12-15-2009 | 07:25 PM
oleblue61's Avatar
My problem is the sb con o I have is that I am to the point of needing to be replaced and I not wanting to go too small if that is the case, is an "o" sufficient or should I get the ofe I am not adding anymore goodies to the truck, the little wife says NO
Old 12-15-2009 | 08:00 PM
Rattletrap1's Avatar
From what I've researched, the OFE will give the same street manners as an O, with more capacity. Beyond that you trade street manners for capacity.
I like my kevlar clutch, but it was like black ops when asking for specs.
Old 12-16-2009 | 03:14 PM
oleblue61's Avatar
So the south bend con o should be sufficient for whats listed or should I go for the ofe. Just looking for an honest opinion guys thanks
Old 12-16-2009 | 06:13 PM
DIESELWRKS's Avatar
IMO just call peter at southbend. tell him how you drive and what you do. and whats on it. I think due to price go with the OFE. I have used stock to OFE to FE and now a DD3600 outgrowing it and towing. so. if I was to do it over again I would have went to what I have now. the FE was to jerky and hard to back up. the OFE did not hold the power I added. (my fault) so wasted money. FE held but I can say my DD with what I have is great peddle pressure is like stock. call peter he will not do you wrong.
Old 12-16-2009 | 10:54 PM
I was running more power than you, with the stock 6 speed (13") clutch. Normal load is 13K, dragging the boat puts me up to 23K. I never had the stock clutch slip, I didn't try to abuse it though.
I blew up my trans (long story) so had the clutch upgraded at the same time. I spec'd the OFE as it gave more capacity without losing street manners. The trans shop talked me into some custom kevlar clutch made locally for about the same $'s. They'd warranty P&L and assured me it would hold the power while be able to slip 1" at a time. It does all this, but I have zero info on specs. I still think the OFE would be an excellent choice off-the-shelf.
Of course, talking to SB might help put you at ease with your choice.
lniemeyer2
10-24-2012 01:11 PM
mitm
08-16-2009 10:29 PM
Dean Snow
09-20-2007 04:09 PM
PapaSmurf
12-19-2003 03:14 PM
Davidp
02-01-2003 06:49 AM
Quick Reply: Hp and Torque Question
