HP on Drag Box
I thought the EDGE Drag Comp was good for like 200 HP.
Do you guys read other websites besides this one? If you go to the edgeproducts website it clearly states that the Drag Comp is good for 120 HP to the wheels. The HOT or Drag upgrade does not increase peak HP, it simply fuels sooner and thus has more area under the power curve... more useable HP. It also raises the defueling point to 3200 RPMs. Not a factor in an auto till you hit 90 MPH or so. Not a factor in a manual if you shift at peak HP instead of over driving every gear.
i was told by edge the drag was 120 hp same as the comp except on the h.o trucks there only 90 hp the drag is diff because it de fuels @3200 instead of 2700 like the comp
i can promise if you every drove or going to drive a truck with the comp you wil love it my rocks it runs like crazy i run my box on the stage 3 (80 hp) and some stage 2 (60hp) but i will crank it up when playing and boy it will run and the chip is a 120hp chip and dont realy smoke that much but i love my box!
sledneck1
02-07-2007 01:57 PM
04ctd
10-05-2006 08:27 PM
Conn
07-28-2005 10:42 PM
CTD_Neil
07-07-2005 11:40 AM
