How well does a SPS62 do for daily driving?
My 62-14 coupled with 90hp DDP injectors is great for intown, towing, and racing.. I've pulled over a 12,000 pound trailer weight for thousands of miles with it.. Did great.. It's also pushing my 2500 to low 12's at 111mph on diesel only.. It's a normal Phat Shaft, and they will upgrade this to the larger ones if you ever choose to do so..
I like my SPS, blackdiesel's old one, but it's a little warm running around. The only thing I've pulled was a 17' bass boat and it doesn't weigh much at all compared to say a camper or loaded gooseneck. I think it's a lag issue more so than it is not supplying enough air. It does supply it, just not right away. Then again I've got 3.54's and a 5 speed. I'm thinking the smarty I just got will help though, but haven't hooked up to anything yet. Just my .02.
So maybe if I put my Catcher back in spooling might be a lil faster? with my 62, Catcher and Quad box this thing spools fast, but from a dead stop hard take off forget about it, right now I think I got it dialed in good on the street, the Drag Comp im using now has turned out better than I thought it would so I dont wanna remove it, this is the hardest my truck has ran since I started this expensive problem of not being able to leave my truck alone I didnt pick up much hp over the TST and stg 5 Jammers, but tq did go up and so its maybe an issue of the turbo not clearing it up and making more hp, im gonna look at a cam and if this will allow me to run cooler and still spool with a lil more top end rush ill do it, how ever im more than happy with my lil 62, im also even more happier with the $200 Drag Comp I just purchased from the classifieds, guy had it listed as an EZ Comp Drag box, it was the best $200 I have ever spent , here is a vid of tuesdays dyno runs, tell me if you think a cam or bigger turbo would clear up the smoke.
http://www.youtube.com/watch?v=y6lShHA9jEw, did 511.1
Buy a smarty so you can try different levels including those without timing to help bring the edge to life. I think if feels like the power comes on quicker using an edge and smarty on 8 that smarty on 9 and a fueling box, but that could just be me, too.
tenmile
07-20-2006 07:07 PM
streetsmoker
21
03-04-2006 06:36 PM
Andrew k
05-20-2005 06:25 PM
Bluedeviltorque
13
07-22-2004 01:05 PM
