How not to Defuel
How not to Defuel
Ok heres the deal
At WOT my truck shifts arround 3100 but defuels rapidly from 2700 on (boost drops from 50 to 30psi) so Piers let me try one of his Drag Comps and it was better but not much? Maybe gained 100-150 more rpm to 2800 or so but still could notice a rapid defuel and boost dropped about 15psi between shifts Does anyone else have this problem?
Yeah most people I have talked to say the same?
I'm not sure what the problem is with mine, it must be a function of the ECM but I cant seem to figure out why? Maybe Marco will have some insight on this?
Make sure it's a real Drag Comp. I was shipped a standard Comp instead of a Drag version. It really shows up in the dyno sheets. Also, you may be running out of airflow with your head/cam combo?
brandon.
brandon.
My drag comp fuels clear to 3200, when it is set to level 4 or 5. On 3 or lower it defuels at about 2700. It really shows up on the dyno. When I had a standard comp it would defuel on all levels.
On a different note, you would be better off to put a 3-4 switch, so you can get it to ship before 3200.
Paul
Paul
[QUOTE]Originally posted by paulb
Paul [/QUOte
I not sure what your trying to say?
Paul [/QUOte
I'm not sure on the 3-4 switch, I'm a manual guy. I suspect he's referring to a lockup, but I dunno. The Drag Comp fuels from 2700-3200 where the Comp defuels. If you look at the following dyno sheet, you'll see where it gets choppy from the Comp cutting fuel after ~2700. Needless to say I was very unhappy with Edge (until they replaced mine free of charge in 7 days)
brandon.
brandon.
Thanks Brandon, do you have a graph with the Drag comp?
That graph totally reflects whats happining to my truck of course at about 200hp less
Originally posted by 2500CTD
Who has that MAD ECM? I tried searching on here, but 3 letters is below the minimum search length and cannot find anything on it. I'm researching boxes now.
and
https://www.dieseltruckresource.com/...threadid=62118
And if you have a couple of hours...try this one - for the complete history of the MAD ECM
http://www.turbodieselregister.com/f...AD+CaTCHER+ECM
RJ
Brandon what is the best 1/4 mile time you have run, our trucks are both 5-speeds but you have 175hp more than me, I have never run the 1/4 before but I would lkike to figure out where i would run I am guessing low 15's maybe high 14's. Can you feel the differnce with the drag comp, being the rpm is higher does it hold boost better when shifting?
Jason
Jason
