how much power you guys think i have so i can order the right transmission
my truck has ats 3000 &5000 turbos 200 hp injecters 215 pump with a 10 plate moved all the way 3k gov springs propane and 5 inch stacks what do you think its around the power you think so i can order a transmission i was thinking revmax they can build one they say will hold 800hp for 5 grand think its worth it?
Probably more pump work, bigger injectors(?), lift pump, your current turbo setup should be able to get you there I would think. 5k rpm and nitrous wouldnt hurt either. As far as engine work you'd have to ask someone who actually knows what they're talking about.
You would need to a billet input and flexplate along with our Signature series transmission, other than that you would be good to go. Now, if you will be doing boosted launches a billet output shaft would also be needed! Hope that helps!
Onemoparnut
01-14-2010 05:24 PM
gregway
11-09-2005 08:47 AM
dealseeker
15
12-17-2002 06:43 AM
