How much power to u think i have?
Hey i have a 96 ctd 5speed, 4.10 gears,p255 85's, turbo back 4inch straight exhaust, K&N fipk intake, 3000rpm governer springs, tst #10 plate, tst clutch, 16cm turbo housing. Just wondered what you think it has while im still looking for a dyno.
Re:How much power to u think i have?
[quote author=CTD 359 link=board=7;threadid=11967;start=0#113273 date=1047147232]<br>332.65 at sea level ;D<br>[/quote]<br><br> : You pull that one out of your backside or what?
Top's Younger Twin
[quote author=OkieBroncRider link=board=7;threadid=11967;start=0#113280 date=1047149684]<br>[quote author=CTD 359 link=board=7;threadid=11967;start=0#113273 date=1047147232]<br>332.65 at sea level ;D<br>[/quote]<br><br> : You pull that one out of your backside or what?<br>[/quote]<br><br>Pulled it from somewhere.<br>I think the 300-330 HP range is probably close. I have been wrong before.
[quote author=CTD 359 link=board=7;threadid=11967;start=0#113285 date=1047153312]<br>[quote author=OkieBroncRider link=board=7;threadid=11967;start=0#113280 date=1047149684]<br>[quote author=CTD 359 link=board=7;threadid=11967;start=0#113273 date=1047147232]<br>332.65 at sea level ;D<br>[/quote]<br><br> : You pull that one out of your backside or what?<br>[/quote]<br><br>Pulled it from somewhere.<br>I think the 300-330 HP range is probably close. I have been wrong before. <br>[/quote]<br><br>Just given ya a hard time. I would say the numbers given are pretty close.
Top's Younger Twin
[quote author=CurtisvilleCummins link=board=7;threadid=11967;start=0#113287 date=1047153695]<br>Is that all u think, cause the plate alone is supposed to be around 330 750.<br>[/quote]<br><br>Rear wheels or fly wheel?
Top's Younger Twin
[quote author=OkieBroncRider link=board=7;threadid=11967;start=0#113286 date=1047153630]<br>[quote author=CTD 359 link=board=7;threadid=11967;start=0#113285 date=1047153312]<br>[quote author=OkieBroncRider link=board=7;threadid=11967;start=0#113280 date=1047149684]<br>[quote author=CTD 359 link=board=7;threadid=11967;start=0#113273 date=1047147232]<br>332.65 at sea level ;D<br>[/quote]<br><br> : You pull that one out of your backside or what?<br>[/quote]<br><br>Pulled it from somewhere.<br>I think the 300-330 HP range is probably close. I have been wrong before. <br>[/quote]<br><br>Just given ya a hard time. I would say the numbers given are pretty close.<br>[/quote]<br><br>You? Give me a hard time? Try harder Okie. <br><br>I get much worse from Push Rod SBOTN with a simple greeting.<br> :'(
Unless you had a weak stock truck you should be closer too 350.<br><br>BUT.... it depends on the dyno and what you started with????<br><br>I did 340 with a #11, exhaust, AFC springs. Added another 25 with timing bumped to 20, 16cm housing, and 3GSK.<br><br>jjw<br>ND
What does everyone get with just the 4 inch exhaust scotty II and Edge EZ? I know the edge is supposed to add about 60 hp but what has everyone actually experienced.<br><br>RT
arren333
08-30-2012 12:57 AM
rock crawler
14
11-19-2008 11:13 AM
jjrightmire1973
08-12-2008 04:29 PM
BossHogg
03-18-2006 06:37 PM
gregway
11-09-2005 08:47 AM
