How much power can i expect?
I can officially say my tranny is not up to the task. When we got it on the dyno and loaded it. The transmission was slipping and holding me back on making numbers.
Stock 309.9 RWHP
559.1 TQ
70HP Box Setting
337.9 RWHP
633.7 TQ
120HP 338.3 RWHP Corrected 382.2 HP
756.1 TQ Corrected 854.3 TQ
There was also a new 6.4 powerstroke out there and it only put down 230RWHP and i forgot the TQ. But i think these numbers seemed a little low. I have read that 6.4 trucks dyno more around 280-290 bone stock.
Later,
Josh
Stock 309.9 RWHP
559.1 TQ
70HP Box Setting
337.9 RWHP
633.7 TQ
Later,
Josh
Was the truck a auto or stick?
And on a dynojet or mustang dyno????? His numbers would have been higher on a dynojet as you know. Hell, look at my numbers. I don't even really believe them.
How high did your EGTs get on the dyno? Mine can peg the pyro at the top of 3rd gear, however EGTs never got over 1250 on a dynojet; proof that the dynojet doesn't load these engines enough for realistic readings.
I did the test on a mustang dyno. I searched around and found that the correction factor was around 13% so that's where that number came from.
What do you want to see? It's just a 4cyl..
If you want i can PM you some more.
Yeah no problem. Thanks for sharing your numbers with me. I am sure my numbers will climb over 400rwhp with a tranny. Because it just ain't cutting it right now.
