How much power can i expect?
Old 03-13-2008, 08:48 AM
91rangerturbo's Avatar
From this setup? Anyone have one comparable?
150hp Jammer 5's
120hp JVD wire tap box with boost fooler (comparable to the Edge Juice or Drag comp)
BHAF
Stock Charger
5" straight pipe
Old 03-13-2008, 10:12 AM
anyone have a similar setup that they have put on a dyno?
Comp or juice with 150's?
Old 03-13-2008, 11:03 AM
stroker4501's Avatar
guessing around 410 to 440 with high temps on exhaust gasses.
Old 03-13-2008, 11:24 AM
JIT
JIT's Avatar
My buddy dyno'ed 402 with Edge Drag Comp, Jammer 5's, BHAF & Stacks. So I would guess you'd bee in the 390-410 range if that JVD is as good as the Drag Comp.
Old 03-13-2008, 11:46 AM
Big Blue24's Avatar
Your wastegate has a boost elbow for more boost right? Your tranny is not stock right? If so, like others said 390 to 410 is a good range. If your tranny is not setup to put down the power, you will only dyno 360 or so.
Old 03-13-2008, 12:08 PM
Tranny is stock. LOL
And thanks that's all i was wanting to know.
Old 03-13-2008, 01:20 PM
BBA
BBA's Avatar
I did 398 without the twins and regular comp and 4" exhaust.
Old 03-13-2008, 05:28 PM
Fishin2Deep4U's Avatar
Should be closer to 450. Even with a tiny charger. Although I don't recall if that box has any timing. Without it, it'll get even hotter and make less power.
I went 560 with M4s, comp and twins. That's also a 150HP injector.
Dave
Old 03-13-2008, 05:49 PM
Dave
I am pretty sure the JVD Torque Enhancer box with boost fooler is a fueling and timing box. It's a old box but works great.
Old 03-31-2008, 07:08 AM
Well just to update this thread. I am putting the truck on a mustang dyno tonight that a friend has in his shop. If anyone wants to make a more accurate guess i will report back late tonight or early in the morning with some numbers and of course video and pictures.
Old 03-31-2008, 10:23 AM
Bjans's Avatar
You'll be between 360 and 400 with a stock tranny and charger with that many miles.
Old 03-31-2008, 11:35 AM
I am shooting for a touch over 400rwhp. The truck feels good but the tranny is holding it back too.
Old 03-31-2008, 04:58 PM
Big Blue24's Avatar
On a mustang, you'll probably get 380 HP and 780 for torque. Thats my guess, but who knows, run it and report, everyone loves dyno numbers.
Old 03-31-2008, 06:24 PM
2141pete's Avatar
Pretty much your setup plus a 62/12 and HRVP got me 525hp
Old 03-31-2008, 09:19 PM
One Stack's Avatar
so what should I get out of my truck. I have a II silver 62-80 and HRVP 100hp sticks, an edge drag comp and a tst.
I will be dynoing in two weeks to find out the reall numbers.
so fair I have 398 with a stock charger and tst on.
Quick Reply: How much power can i expect?
