How much more on a Dynojet?
Just curious, assuming weather conditions are the same, no changes to my truck, how much would I dyno if I dyno'd on a Dynojet versus the Mustang dyno? I always see guys dyno'ing quite a bit more on a Dynojet. My hp/tq are in my sig.
My expirience from both Dynojet 248c and a Mustang 250 is that a Dynojet will produce 10-15% higher numbers... IF the Mustang is loaded to match the road weight of your truck.
It is possible to simulate a Dynojets #'s on a Mustang by loading the Mustang to the same weight as the Dynojet Drum, which I believe is around 1700 lbs.
RJ
RJ
Interesting info, thanks. RJ are those numbers in your sig with meth/h20? if so what did you dyno without the meth/h20? I'm going to be getting some Mach-4's and I'm curious how much more i'll gain over my dd-3's?
Yes, As stated in Signature...with H2O/Meth.
Both w/ and w/o are posted in my gallery!
I used a lighter mixture than some.... about 40% Meth, and got about 25 hp, I think.
RJ
RJ
Well I signed up for a local dyno day. The shop has a Dynojet dyno. I'm curious to see what I get on this one compared to the Mustang I ran on in Oct. Any guesses?
Luvnacumns
45
05-21-2007 09:11 PM
ppsi
21
03-23-2004 06:49 AM
