How much HP does my K&N and 4" exhaust
Really? No back pressure? So the power output would be the same between a truck with a 4" exhaust and a 1" exhaust, just the EGTs would be WAY high on the 1"?
If you are horribly overfuled air (from intake/exhaust) can add power, mostly because it can let you stay on it longer/harder.
But EGT issues (like would be caused by 1" exhaust) would reduce power, because you would not be able to inject enough fuel to produce boost, and burn lots of fuel without having top back out due to EGTs.
A k&n drop in with the boot removed and my 4" exhaust seemed to work great for the dyno pull in my sig. So these mods may not make power by themselves, they will support up to 500 hp
It is the pressure reduction downstream of the turbo (turbine) that a 4 inch exhaust tries to remedy. Keep in mind that the stock 3 inch exhaust works fine until the engine Hp goes over a certain point. At that piont the exhaust pipe can't flow all the exhaust gas efficiently so pressure builds up.
FWIW many gas turbines operate using differential pressure. The turbine on turbo chargers is one of them. To raise the shaft Hp output the differential pressure needs to be raised. The differential pressure is the inlet pressure minus the exhaust pressure. Raising differential pressure can be done by raising the inlet pressure or by lowering the exhaust pressure. The larger exhaust pipe functions to lower the exhaust pressure of the turbine. That makes the turbine more efficient. The result of higher turbo efficientcy is higher engine efficientcy.
Jim
Basically, horsepower increases in a diesel engine come from adding fuel. The intake and exhaust just provide some additional air to burn that added fuel, but do very little by themselves until fueling mods are made.
The bombing cycle generally runs - add more fuel, then figure out how to add more mass airflow (oxygen) via turbo(s), intakes, exhausts, nitrous, etc. to burn it efficiently. One can always add more fuel to the engine - getting the additional oxygen to burn it is the challenge.
Rusty
Rusty
A free flowing exhaust and kn type filter will often not result in a net higher peak horsepower BUT...it will allow your engine to achieve its max power quicker with faster turbo spool. So basically you will feel your max hp quicker and also have some added torque in the lower rpms.
Another thing that combo will do is lower exhaust gas temps.
