How much boost can be run on a stock 12v engine?
Its not boost that is the worst on HG's it is cylinder pressure. If you keep it wastegated to control it you won't have as many problems. I think if you add studs you will be perfectly fine up to 55 PSI...
So with my mods I can run at 38 all day?
Displaced Texan says he has run it for 45k miles with no problems...
I just want to make sure its cool before I start getting into this thing...
I don't really completely agree with that, there are other variables to factor as well. That could be VERY possible though! AFC position, starwheel, timing, etc... can affect it. If I set my afc and starweel to FF my truck is a DOG because it overfuels, it won't light until 2100rpm or so. If I adjust that stuff right it will come on at 1400ish and completely rip at 1750.
