how many have broken billet shafts
Old 05-13-2007, 05:36 PM
MillerTime's Avatar
Question how many have broken billet shafts
i just snaped the stock input shaft off in my suncoast 3disk last week.2 weeks prior the flex plate snaped and was replaced with a stock one. It took the front pump with it this time.Had to send the converter to suncoast to get the shaft removed.
my plans are replace the front pump and upgrade to the suncoast flex plate and their billet input and output shafts
my question is how many have snaped billet parts on a non sled pulling truck
Thanks
Tim
Old 05-13-2007, 06:18 PM
pokapotato's Avatar
Are you doing 4x4 launches? When I bought my trans I had to at the very least buy the billet input shaft or they wouldn't allow their warranty to be in effect for the HP range. Sounds like you need a billet input shaft and flex plate. Thats a quick $2K. I would imagine that the right abuse or conditions you could break a billet shaft.
Old 05-13-2007, 07:12 PM
MillerTime's Avatar
have not done any launches in 4WD. i would like to go to the track with it once i get it back together
it's less then 2 grand for the billet input and flex plate, $1174 off their site for the pair.
Old 05-13-2007, 07:41 PM
Dshiftff's Avatar
Animal.....
Old 05-14-2007, 12:24 AM
CL2000's Avatar
I just broke a billet shaft yesterday and broke the pump drive and the piece of shaft is stuck in the converter.. It lasted almost 3 years of abuse. Towing sled pulling and lots of 4wd launches!Im pretty happy that it lasted this long the truck was at about 400hp for about 2 years and 500+ then nitrous on top of that for the past year or so. And this is with 37s
Old 05-15-2007, 07:50 PM
ctturbodiesel's Avatar
Hey Dieselpowerinct if you take that thing to the track you better call me! I'll take a ride up.
Ken from CT
Old 05-16-2007, 07:53 PM
MillerTime's Avatar
Ken from CT
you bet,just gotta get it together again
Old 05-19-2007, 06:17 PM
Munchies's Avatar
Goerend has cheaper shafts. call dave and get a billet input intermediate and ouput with a billet flex plate. Pull it apart and stab it back in. Should only take a weekend.
Old 05-19-2007, 07:14 PM
1qckdodge's Avatar
Here is Tims truck in action, I snapped this vid as he was headed out for a normal routine drive http://www.youtube.com/watch?v=JpNmnlZFHXg
Old 05-19-2007, 09:18 PM
Dshiftff's Avatar
Yeah he was going easy there musta had the kids in the truck or somethin'
Old 05-20-2007, 01:24 PM
RowJ's Avatar
Over 500 hp you are living on the edge, IMO, with a stock input & output shaft.
RJ
Old 05-20-2007, 04:18 PM
schoust's Avatar
Guy's if and when your planning going up to the Valley and running your trucks I would love to see what mine can do for Ha Has.....
Old 05-30-2007, 05:43 AM
MillerTime's Avatar
figured i would post the pics of what i found when i pulled the tranny out
i ended up replaceing the stock flex plate with the suncoast one and did billet input and output shafts.
Old 05-30-2007, 06:26 AM
Mike D's Avatar
You're not the only one with a Suncoast who has done that kind of damage. Sorry for the bad luck.
Edit: I don't mean this to come across as a slam on Suncoast products. A friend of mine has a Suncoast and had similar breakage.
Old 05-30-2007, 01:04 PM
gmctd's Avatar
Scary stuff, but, while that input shaft wasn't designed for that type power, it shattered amongst the splined end, not at the drum - the previous flexplate damage probably initiated the failure.
Good reason for the 305\350hp flexplate and high-tensile steel input shaft in the 48re, and better.
Quick Reply: how many have broken billet shafts
