how to make intake tube
Old 08-20-2010 | 05:08 PM
blue2002's Avatar
does anyone know how I could go about getting the pieces of making my own intake tube? what is the best air filter to use?
Old 08-20-2010 | 05:59 PM
wyododge's Avatar
Search BHAF. Big Honkin Air Filter. Just about everything you could want to know, and a bunch of stuff you probably don't.
Old 08-22-2010 | 04:58 AM
JasonblkZ06's Avatar
I think you mean a replacement intake tube like the kind that come with some of the intake kits or the AFE torquetube. I have this on my to do list as well. I am just going to use an aluminum 4" 120 degree mandrel bend and weld another piece to that. Then I will smooth the weld down and get it ceramic coated inside and out. Back when I was into turbo imports we would get like 10-12 HP on the dyno and a huge turbo sound on a DSM from switching the stock rubber intake tube to a hard inlet tube. This was after an air filter upgrade and only from changing that 1 part out.
Old 08-24-2010 | 08:20 AM
Ozoneburner90's Avatar
go to the cummins forum and type in the search bar, home made intake tube..i made a whole writeup about this and have pictures..
Old 08-24-2010 | 05:26 PM
blue2002's Avatar
thanks all of yall so much for the help!!!
Old 08-25-2010 | 12:54 AM
Was not able to find it. Also searched under your posts with no luck.
Old 08-26-2010 | 07:15 PM
Clunk's Avatar
I really like the design of the AFE Torque Tube but it's gotta be the highest priced piece of cheap black plastic ever....why can't the chinese rip-offs copy and sell that instead of shiney turbos?
Old 08-27-2010 | 08:57 AM
high bid's Avatar
1. Find the air filter you want to use
2. Measure the ID of the air filter intake...where you would attach it to the turbo intake hose.
3. Ideally, you want to match the air filter intake ID to that of the factory turbo intake ID.
4. Go buy sch 40 pvc from your fav plumbing supply which has OD of exactly the same ID of the air filter & turbo intake ( IIRCC think 3.5").
5. Paint the pvc w/heat temp paint.
6. Put everything back together.
7. Cut about 6-8" of garden hose and cover the a/c line the filter will possibly now rest on to prevent the filter from wearing thru the a/c line.
Old 08-27-2010 | 09:37 AM
PVC? I guess on a budget. I am making mine out of mandrel aluminum.
Old 08-28-2010 | 12:00 PM
high bid's Avatar
From my understanding the pvc will work fine and conducts less heat xfer than metal, thus keeping the intake air lower. JMO.
Old 08-29-2010 | 11:31 PM
here is the link. http://www.cumminsforum.com/forum/98...tube-pics.html
Old 09-07-2010 | 05:20 PM
blue2002's Avatar
where did he get that rubber gasket between the turbo and the pvc?
Old 09-07-2010 | 05:29 PM
benboonie's Avatar
From: Then, raised central PA; Now where ever Uncle Sam sends me.
search for the will'y whistler... Seems to be best for your money....
Old 09-08-2010 | 02:26 AM
DIESELWRKS's Avatar
here is a place that has alot of pieces takes longer to open and look in the pdf catalog's..
http://www.google.com/url?sa=t&sourc..._uhK_5Q52WzwNQ
Old 09-11-2010 | 02:34 AM
Yeah, but it is PVC pipe.
CACalomino
05-31-2009 02:35 AM
dieselcarpenter
03-26-2008 06:08 PM
Dean Snow
09-21-2007 02:18 PM
natlchamp2k4
03-13-2007 06:47 AM
