how to make a 500 HP 12 valve
Old 09-18-2007, 06:07 PM
smknram's Avatar
thanks rick, i will just have to keep messing with it. how should the governor arm be adjusted and how do you adjust it? i have never messed with that. and BOX5- my boost is 48-50 psi and my tranny is in great shape
Old 09-19-2007, 01:19 PM
Teddy Bear's Avatar
You shouldnt have to worry about adjusting the governor arm if you have 0 plate, unless it is actually going underneath the plate.
Old 09-19-2007, 07:55 PM
rootremblay's Avatar
Ive got 215 pump and injectors with a # 10 plate, I hit 310 hp at 48 lbs boost on an hx35 ( why Im doin a head Gasket job also ). I think with your setup you should be seeing higher numbers. good luck to gettin to your 500 goal
Old 09-20-2007, 07:14 AM
smknram's Avatar
well my governor arm is hitting the plate so i guess that rules out the governor arm. i messed with the last yesterday for a ouple hours moving the plate and adjusting afc and still havent got it to run any stronger
taterramin
27
07-07-2009 09:29 PM
1985cucv
05-18-2009 08:35 PM
mouseguy
33
09-26-2007 06:12 PM
Hummin Cummins
02-11-2003 12:14 PM
Quick Reply: how to make a 500 HP 12 valve
