how to get 450hp
how to get 450hp
I got everything in my sig, and want this hp goal. I know about the gsk, injectors, turbo, and all that i just dont know what combinations work good. I mean what injectors go good with what turbo to get me my hp goal. Twins arnt an option for a turbo so this makes it a bit harder. Money isnt that big of an issue here either. Please name the products and where you got them.
thanks
thanks
just remember those 38s are gonna kill the hp on a dyno. my setup gets 475-ish on a stock height truck with 265s, but I pulled 435hp 1000lbs of torque with 37s
The bigger tires might actually help you because they will load your engine a little better due to the mechanical disadvantage of your truck on the dyno as most dynos can't properly load a diesel.
I'd say head studs, 5x.012's, 4k gsk, and a 62/68/14 from Engineered Diesel. The 64 might be a little tough to tow with if you went with a 64/71 or you might get surging with a 64/65. As soon as you move the fuel plate, you will need to get your auto built up.
camshaw
07-10-2007 01:00 PM
dodgezilla04
31
11-13-2006 01:22 PM
65fury
09-10-2006 11:40 PM
streetsmoker
11-03-2005 06:13 AM
