How To Get To 400hp-500hp
hey fellas im needing some help of coarse i know jack about mods or diesels i know where the gas pedal is and thats about it the only go fast mod i have is a edge juice with a a2 monitor i want my truck alot faster and to roll the coal im used to driveing mustangs with a supercharger a 2005 crossfire i love the speed but im to the point where i wont get rid of my truck now due to getting stuck in the snow in my crossfire so i sold it and got this truck from my family and im ready to do some things my truck is set up right now exactly like it says in my sig also im gona go for a new trans when the stock one goes out thats the plan i was going to buy a smarty to put with my edge juice but really dont know what to do i want to be able to stomp it and kick the truck sideways with a cloud of black i want to beat mustangs and camros thats all ill be doing with the truck its a daily driver not a sled puller and i dont haul anything with it i live in indiana if that will help and im open to anything injectors turbo different chips programers whatever i just need a good plan laid out so i can start buying things one after another it also would be very helpfull if you could say what to get first second third fourth so i dont get things out or order thanks in advance for all the help guys cause i know jack about this stuff
Upgrade your fuel system (FASS, Airdog, Holley, etc), some 150hp injectors (Mach 4's, DDP's, etc.) and a turbo (62/71, GT3788R, Turbonetics of some sort), and a clutch should get you there(Southbend, Valair). Easy 400hp for sure. Your HO pump might hold you back when approaching 500hp, so you might want to get an SO pump if want to go beyond that.
Tate has a pretty good list there for you. I would put a fuel system on there first, fass, walbro, airdog system. Second i would put a clutch on, call peter at southbend and he will set you up right. Then you can get some stage 4,150s or stage 5s, 200hp injector from f1 or ddp. Next you will need a turbo, a 62/71/14 or 62/74/14, or if you dont tow or haul any heavy wieght look at 64/71/14 from htt or II. Then you can get a smarty to stack with the juice. After all that someday the vp44 will quit on you and you can buy an so vp44 and you will have a nice 550hp setup.
I agree with the posts above,
1. Gauges- fuel pressure, pyro, boost and a upgraded lift pump ( fass, air dog, ppe, holiy blue)
2. Cold air intake
3. 4"-5" performance exhaust from turbo back, muffeler optional
4. A south bend clutch
5. Hot unlock for the edge
6. Mach 4- Mach 5 injectors
7. Twin turbos and arp head studs ( if your boost gets more then 40psi with which ever turbo you go with, you need head studs)
8. Smarty stack
9. SO injection pump when HO gives out
10. Water/methan injection
11. Traction bars
12. F1 cam
13. Port and polish head
14. This one should be close to the top but switch over to full synthetic fulids in ever cavity.
As you will find out once you catch the power bug you can't stop and the list will go on and on. Not sure how much hp this setup will give you but you will be able to choke the mustangs with your smoke. Oh and just because you are rolling out the smoke doesn't mean you have power. While it is fun, it is a waste of fuel and power from lack of air. A diesel that is tuned right should only smoke alittle during turbo lag.
2. Cold air intake
8. Smarty stack
11. Traction bars
12. F1 cam
A fuel system, injectors, clutch, and turbo are all you need for 400-500hp, but all the other stuff helps too. Do an exhaust with the turbo so you don't have to swap downpipes twice.
ok guys thanks for the help i think you all got me in the right direction also is the juice with the a2 monitor good enouf for the 2001s i know ive heard alot about the smarty but whats gona be my best option out of all these between the edge juice , comp, comp drag, smarty, tst, quadzilla addrenaline, its like theres so many and im sure everyone has there opinion i love my juice with a2 well i actually like the a2 monitor how everything is right there included with the gps i really like it but would the juice and smarty work ok together im justing looking for 2 good stackable chips/programers and i know you guys have lots of smarts when it comes to this stuff
Your juice will stack nice with a smarty and you can get the hot unlock on your juice for the most out of it. The new hot thing is quad ADR / pulse it will have all of your gauges and will give you more hp. It has custom tuning high idle turbo timer among many other. A lot of people are running it and love it and some stack it with a smarty as well. So if you are happy with what you have stack a smarty with it. If not then sell it and get the ADR/pulse box for max power.
Get the hot unlock for the edge and you'll be competitive with any stacks of chips out there as far as dyno power goes. Smarty is great for a lot of things, but at the point you're at you need fuel more than anything =P That's why I said fuel system and injectors- more fuel in and fuel out
rip 112
68
01-11-2008 12:38 AM
Out Back 4x4
44
09-10-2007 10:19 AM
YZ3500F
06-25-2007 10:38 PM
