This is how the EZ pin settings work. FYI.
I called Edge Products and this is what they told me.<br><br>Pin setting #1 will give 33% fueling at 0 boost untill 20 psi then 100% fueling.<br>Pin setting #2 will give 50% fueling at 0 boost untill 15 psi then 100% fueling.<br>Pin setting #3 will give 67% fueling at 0 boost untill 10psi then 100% fueling.<br><br>Stock injectors on setting #3 because the stock setup can handle to extra fuel of the box without dealing with any added fuel from injectors.<br>Mild injectors on setting #2 because the injectors will add more fuel so the box has to decrease its level of extra fuel untill a higher boost level to control smoke.<br>Big injectors on setting #1 so the box will add the least amount of fuel untill the boost level is 20 psi or more to compensate for the extra fuel delivered by the injectors.<br><br>Thought some of you guys runing the EZ would like the info. I was going to change my pin location untill I found that I would be getting less fuel untill an even higher boost level. Not what I was looking for!
marksman
08-10-2006 04:20 AM
