how does it work???????
Old 02-02-2009 | 09:09 PM
fiveology's Avatar
You could start with this, not cheap, but pretty much everything you need. It would obviously require some custom plumbing on the air side, as it is not designed for our trucks.
http://www.vortechsuperchargers.com/product.php?p=19
Old 02-02-2009 | 09:34 PM
Flatbed24v's Avatar
ya that a nice system ^^^^^!!!! But I think I could build one cheaper
Old 02-02-2009 | 11:56 PM
jnicewan's Avatar
how about using a regular air to air, then plumbing in a water mister type device to spray on cooler kinda like a swamp cooler does. maybe work for for short periods like pulls but not too good for street use.
Old 02-02-2009 | 11:57 PM
Lil Dog's Avatar
Originally Posted by Flatbed24v
Where could I look this up at? Any cummins part house should have one right? I still want to keep my air2air one in, so I wonder the size of it
I don't know the particulars, but I have seen this in application as a firewater pump install 6BT. The cooler looked like it just sat right in the intake manifold and bolted straight on. The intake horn was part of the water cooler. I am sure it was piped into the jacket water, but you could have a small water reservoir with an electric pump to circulate. For a pull you only need a 1 minute charge right?
Old 02-03-2009 | 09:29 AM
Mike Holmen's Avatar
The Guru
Most racers add ice at the track. You could also run a coolant fan, you could use a rad out of a small car. A large tank is better than a smaller one. I would put everything in the bed of the truck. How much boost you planning on running? If you go twins, put in a interstage cooler between the primary and secondary. This will drop the air temps going into the secondary. Then have another intercooler. I plan on doing this one day, but I want to run my boost around 100+ psi area so, the air will be hot hot... I'm guessing around the 450 to 500 deg F area coming out of the secondary.
skahla
11-20-2009 09:13 AM
cheese4420
04-13-2008 12:50 PM
96_12V
07-08-2005 12:26 AM
midwestdually
12-12-2002 02:57 PM
