how does my fuel pressure look
I just installed my fuel pressure gauge the other day, and when its at idle its about 15 psi and wide open its at about 7 psi. just wondering how those numbers sounded and if i need to do a big line kit or anything.
that sounds about what they should be stock....you just want tomake sure it doesnt go below 5...my stock lift pump went out, and i went with a bd kit on the frame rail, no big line kit or anything like that yet, and i now have 20 at idle and 15 at wot..
Pressure sounds like what I recall from stock!
Big Line Kits do help keep pressure up and protect lift pump. If you'll be adding HP...it's only a temporary measure.... but will cover FP needs to about 325 hp.
RJ
RJ
just wondering what you mean it will only cover up to 325? whether i shut the comp off or have it on 5x5 the pressure doesnt seem to change any.
When I got over 325hp ( I think) my FP started to get pulled below 5-7 psi! All I had at that time was a big line kit and my original factory lift pump. Adding bigger injectors to my EZ made for a big drop??
RJ
RJ
SILVER GUS
11-15-2008 06:34 PM
merrillr4
34
06-21-2007 08:20 AM
carcrz
08-12-2006 09:52 AM
widlin1
13
03-17-2006 04:52 PM
darrenG
06-28-2005 08:43 AM
