how do i ?
how do i ?
hey how do i erase codes? just un-hook the batteries for a little bit or is there some special way of doing this? and also how would i replace the apps? i'm pulling the 0122 code so yeah..........thanks
P0122 - Throttle Position Sensor Voltage Too Low
To actually delete the DTC code you have to have a tuner like a smarty, or take it into a dealership, the get rid of the check engine light, you have to turn the key on and off like 5 times pretty quickly, i believe..
