How big of injectors
Alright help me out here, What is the biggest size injector I can use and still pull my horse trailer without having to worry about breaking something? The truck has a 135hp chip, Full sun coast tranny, and AFE intake.
Thanks,
Travis
Thanks,
Travis
If your pulling a one-horse bumper pull, then the sky is the limit...( i feel sorry for the caballo)
But, if your pulling a 40'-4 horse slant, w/20' of living quarters, then you might want to turn your chip to low setting, and get some mach 1.5's or 2's. i understand that a 65 hp chip & mach1.5's are a good pulling combo.
what kind of trailer are you pulling?
I run a EPcomp as an EZ when pulling. It pulls a 20' stock trailer w/ 6-8 steers & 2 horses in the back great. But im a flatlander, and I never see hills. So a box is all I need.
Sorry to tell you, but the Bank$ 135 hp chip doesn't make 135hp. Maybe 100. The reason is that Banks, like many others, advertises the MAX hp gained, even if that occurs at an rpm different than where they engine makes its max hp. So the increase at peak engine HP is usually less.
Example: if the engine makes 300hp@2000 rpm, and the chip produces a maximum increase of 130hp, this most likely does NOT occur at 2000rpm. The amount of gain the "130hp chip" produces at 2000 rpm is probably more on the order of 100hp. So they truck will dyno 400hp and only "see" a 100hp increase.
To answer your question, though, go with a mild injector. The best towing injector is the Mach 1.5, bar none. It makes the most grunt, gives the best mpg, and makes almost no smoke.
Justin
Justin
Mach 3s here with fuel mileage of +2.4mpg over stock and the same as with DD2s at 18.7mpg. About 95% at 60mph to 62mph driving, the rest is easy in town driving unless there's a ricer sitting beside me at a light. I haven't towed with them yet, but soon.
Shaders 24v
08-11-2003 11:18 AM
