Hot Rod Vp On!!
Hot Rod Vp On!!
got er on today heres what i noticed:
Smooth idles (i wish it loped) higher idle 900 rpm.
3 psi increase wot, egt finally past the 1300 mark.
tremenous top end power.
One thing tho. if you give a lil throttle i gets real lopey, maybe even sounds like a miss. but it doesnt do this under load or idle. any suggestions?
That's where mine sound lopey- right around idle when the clutch disengages. I'm thinking maybe setting a higher idle would eliminate the lope.
So did ya peirce the wire yet?
I have a friend that bought a drag comp and tapped the wire. Well that lasted about 30 minutes and his vp decided to quit. So he went ahead and got a HRVP. It lopes like a sombuck at idle. It runs pretty dern good with just the HRVP. Is it normal for these pumps to lope like that? It sounds almost like a miss.
Administrator / Scooter Bum
From what I've read, it depends on the builder and what they do to make it a "HotRod" pump.
My Industrial Injection pump doesn't lope, but I've heard that some of the other builder's pumps do.
Originally Posted by Big Deezul
My idle is pretty high like 900 when in gear a/c on...not sure how much higher you would want to set it.
At idle mine is smooth, but when I load the engine the rpms drop below 900 and I get lope. Usually this is a 2nd gear start and I have to up the rpms a little before engaging the clutch. It was amusing at first, but can be annoying. I'm guessing the guys with autos may or not experience this depending on how their transmssions (T/C?) loads the engine.
Originally Posted by Ph4tty
Mine too. I'm thinking another 100 would be good. I'm thinking if I got Marco to up idle to 850 the hrvp would probably sit at 1000. Any disadvantages to a higher idle besides fuel consumption?
Badd Dogg Guy19
01-18-2008 09:19 PM
Strjock81
16
12-12-2007 09:53 AM
duallydave
08-07-2005 09:38 PM
