Hooking up fuel pressure guage
Need help asap with fuel guage!
Can you use any fitting to attach the fuel line to the schraeder valve on the bottom of the fuel filter housing? If so, does it just screw on? Thanks a bunch!
Ian
EDIT: Leaving for California on Friday, and I need to know why my fuel pressure guage reads 15+psi at idle and goes down to about 8-9psi at wot. Any ideas?? I'm totally lost...I would have thought that it would be 8-10psi at idle, and 15+ at wot...
thanks a bunch.
Ian
thanks a bunch.
You'll need a piece that has the fitting for a Schrader Valve on one end and a 1/4 npt fitting for your gauge to connect to. The hose on my basic auto parts fuel pressure test kit has both and that's what I use. Lots of guys install a fuel pressure "T" fitting available at speed shops, on the rubber line that runs from the filter to the VP....probably your best option.
Because you're running an Edge comp, you might need to upgrade your fuel lines & fittings to get enough fuel pressure at wide open throttle (WOT). Scotty's Smart Fuel (a site sponser here ) looks good...you can ask about the fuel pressure gauge fitting too. I'm taking my drilled banjo stuff off and buy better fittings for better flow soon.
2500Ram: its where I'm installing my guage permanently
I hooked the fuel guage up last night at the shraeder on the fuel filter housing, and the guage was making out at 15+ at idle, and would drop whenever I accelerated. Any ideas what could cause that?
I'm rerouting it to the schraeder off of the injection pump with the needle valve tonight, hopefully it will read properly this time
I used the test kit line, grease gun line extensions and fittings to get pressure from the VP to inside my cab. It's not pretty but it works. Someday I'd like to install a dash pod with lit guages but I'd still use my test kit/greasegun extensions...the test kit has a bleeder valve for bleeding the air off my system after a filter change, it's kinda handy. I guess I need to take it apart and lay it out then take a picture & post it in my gallery.
Ian, my pressure drops upon acceleration too as does most everyone else except the guys running a big pump type system.
It doesn't bother me until my pressure at WOT goes below 8psi and a set of injectors will likely send it that low so my next move will be straight fuel fittings.
EverydayDiesel
11-29-2007 12:14 PM
HDBeauty
04-12-2007 05:26 PM
bigragu
01-24-2006 11:16 AM
