homemade trac bars
homemade trac bars
im thinking of making some traction bars for the old dodge (^^^). ahave good mechanic skills and im confident in my welding so i know that i can make them. does anybody have any specs on how the built theirs or how they would build theirs.
Matt
Matt
Would be curious what others have done as well.
But i was thinking I might try it with some 1.75 Dom tubing about 60" long. To a shackle type joint ( don't know what it would be called but picture it in my mind) i would run two tubes obviously but bend one to save as much ground clearance as possible.
here is what i did, i jot some centerlinks for a tractor @ john deere, cut in half and extended them, then made a plate for the bottom of the u-bolt plate, ran the u-bolts through the plate, then made brackets front and rear, and welded up
![Name: l_baca5ef69c854e889643999e8d7c2cee.jpg
Size: 39.2 KB](https://www.dieseltruckresource.com/forums/attachments/performance-accessories-2nd-gen-only-91/68027d1501301279-homemade-trac-bars-l_baca5ef69c854e889643999e8d7c2cee.jpg)
im thinking of doing something similiar to this, being adjustable is always a plus. i think i need 1/4" wall tubing and then the adjustable end links
