Holy Mother Of....Smoke
What size exhaust do you have. If you still have the stock exhaust a 4" exhaust is going to cool your egts more then the scotty II. From what I've seen the scotty II only drops egts about 50* over a BHAF.
Originally posted by BigBlue
At WOT from a 20-95 run it hits about 1400-1450* pre turbo.
I just limit myself to 5 sec max...once it hits the peg on the pyro (1550*) and have had no troubles. 5 sec is conservative by some peoples standards...but that's just me.
At 1450*, DD4x4 could probably play with 7-10 sec, easy.
Can you say 1-mississippi, 2-mississippi, 3..........
RJ
Word of advice to yall. Make sure that when you reinstall the shifter that you thread lock the bolts and put a bead of silicone. My buddy had to put 2 quarts of fluid in because it was leaking so bad. Changed the fluid today, thread locked the shifter in, and so far so good. This truck is just insane. Everytime he hits the throttle I just smile and laugh. It's great.
I guess when I did that run last night, the air temp had a slight effect on the egts and I was still a little hesitant on the throttle. Today, during the heat of the day, I was able to hike 'em up to 1450* give or take. Now its time for the ol' duce air intake.
Like the roommie said, I'm all smiles . Now all I need is to pull up next to some cocky ford guy and let him know who's boss!!!
Ace
11-22-2006 06:26 PM
