Holy cow!
1 Post
Holy cow!
Put the Scotty Air II in today, with the cowl hole drilled, and pulled the silencer ring. Dang it's loud! I may have to put the silencer ring back in; depends on whether SWMBO complains a lot or not.
This might be a stupid question, but was I supposed to remove the grommet thingie in the fender hole that the stock air box fit into? The cowl end of the Scotty intake doesn't go very far into the cowl hole, so I'm just wondering if I put everything in there right or not.
Is it loud enough that you won't be able to hear SWMBO complain?
(If it is, I might have to get one).
Not sure if you are supposed to remove the doomaflachie or not ("thingie" is NOT a technical word)
Congrats,
~Rob
Congrats,
~Rob
I ain't got one of those in my DOG HOUSE I do have a significant other and she does hold the purse strings for me, Chucks I,d be as poor as a church mouse if she didn,t. But "obey" wasn't in our vows. But I kinda got off track here. Has anyone installed a functional scoop on a 1st gen.?
1 Post
Congrats,
~Rob
Congrats,
~Rob
(Oh, and thingie is an IT word.)
1 Post
Originally Posted by shortround
I believe what Rob is refering to is a "goesinta". Reason - it's the item that goes in to the turbo inlet.
Originally Posted by jfpointer
I'm not sure I'm buying Rob's terms after reading about his toilet problems.
~Rob
I went so far as to test mine...with & without the rubber "grommet thingie". No difference in max boost reading...so it's your choice.
I put mine back in after a 1,000 miles because it seemed to hold the Scotty II in place a little better! My Scotty II does not protrude into the firewall hole, like some, it just rests against it, so a little added support could not hurt.
Scotty posted once that different model trucks (RC,QC, LB,SB, etc) result in slightly different Scotty II placement with reguards to the hole....and that all work equally well!
Daily driving works VERY well with the hole covered up...better than I would have thought. Another option is the TAG System...quiets the wine down a lot.
RJ
1 Post
Originally Posted by rjohnson
Only took 10 posts for you to get an answer....some people have entirely too much free time!
RJ
RJ
Thanks for the observations. From your description, it sounds like mine is roughly the same in how much it hits that cowl hole. Just part of the inside edge (nearest the motor) protrudes through the hole. I think I will have to put the silencer ring back in. The whistling is very annoying.
1 Post
No problems with my plumbing now And I can tell you what to do with that goesinta doohickie, but it'll cost ya' $142.00
~Rob
~Rob
Dieseldude4x4
53
11-12-2002 07:00 PM
