Holset PRO 52 Trubo
I found one today. It has a 71mm inducer and a 16cm exhaust housing with no wastegate. They said holset does not recommend to spin them over 112,000 and that would only produce roughly about 28lbs of boost. At least that is what I was told.
van haisely blew one up at 62psi.....wastegated at 50psi is good enuff 35-45 psi efficiencey range maybe.
bythe way sleds that 66 keep the egts decent with the jam 5's?
With the drag comp on level 5 egt's will barely hit 1400 in fifth gear with the pedal to the floor, but by the time it gets that hot your at 3400 rpm doin a 130 mph and have to shut down anyway . I also live at 4500ft elevation, so if your at sea level egt's should be even better.
Sleds, do you ever tow with that htb2, I am looking for a good single turbo to pull and tow with. BTW what are the jammer 5 injectors rated for hp, just for comparing them to my inj. Dean
Bersaglieri
21
03-10-2010 03:23 PM
sway825
12-08-2004 10:21 PM
