Holly blue install
Old 01-27-2005 | 10:50 PM
OldSmokey's Avatar
Holly blue install
I just got a new holly blue fuel pump but when I unhooked the stock lift pump I found that I didnt know which wire was the hot wire and which was the ground. Can anyone help. Thanks.
Old 01-27-2005 | 11:47 PM
low c1500's Avatar
Yellow'ish wire is positive. I just installed a holly blue yesturday as a pusher pump. Pleased with the results so far.
Old 01-28-2005 | 01:41 PM
airman's Avatar
Thumbs down Blue Holley
I am new here but have been reeding post here for a couple of years,it has been very infomative and usefull.Any way I tried the blue holley on my diesel and it work very well for about 15,000 miles then it started lieking fuel.duiring the holidays so I robbed one off my race car to get me by till I could get a new one.The thing is they run good preasures but the seals in them will not handle diesel fuel.I put a high performance Carter on that is rated for diesel.Works just as good so far.I would also recamend moving the pump just in front of the fuel tank ! it will work much better and last longer.
Old 01-28-2005 | 05:05 PM
600 Megawatts's Avatar
Muted User
Cant say I understand how a seal which is rated for gasoline (which is in effect a solvent) would not be fine, actuallaly better off, with diesel (which is an oil)....
Kevin
Old 01-28-2005 | 08:16 PM
RDLeader's Avatar
Kevin
Me neither
PowrStorkthsRam
08-26-2007 03:49 PM
DODGER BOMBER
18
06-16-2006 02:54 AM
xloudnproud
04-11-2006 07:48 PM
SuperDave4x4
07-18-2005 09:23 PM
Tengu
33
04-27-2004 10:03 AM
