holley fuel pumps
![Smile](https://www.dieseltruckresource.com/forums/images/icons/icon7.gif)
thinking of installing a holley fuel pump, I've heard that these pumps are pretty good for using as lift pumps for diesel, we used them in racing with no problems. Do you guys have any problems with holley pumps. FASS pumps is a little high on price. Thanks TIG
Holley makes a good pump, but do a search on lift pumps here and spend some time reading what others have writen about them.(Lots of info, so be prepaired to read alot)
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
I'm running a holley blue and have been for the last 3 years with no problems (knock on wood). Even at 398hp I can only pull it down to 11 psi at WOT. I am running -8 line from the tank to the injection pump though. I couldn't be happier with it. It's lasted longer than any factory lift pump or other aftermarket I've ever ran.
I have had real good luck with the Aeromotive 11203. Rated at 16 psi
16psi at idle, 12 psi at 65mph and rarely drops below 10 psi under load at WOT. Use one for the veggie side as well.
Q
Q
Mark Thomas
07-22-2004 09:36 PM
