Holley Blue wiring question... Relay???
I've been running the holley blue setup for a while... I've got it mounted on the frame in front of the tank. One line run to the stock suction line at the tank (top) and the other to my factory fuel filter. Then, factory piping to the VP. Any way, I made a Deutch plug at work and wired it to the holley so that the Deutch plug will plug into the factory lift pump connector and it seems to be working fine, but I got to thinking... The FASS system uses a plug there but "I THINK" (if I remember right) that they also use a relay somewhere too.?..?
My question is: Will it be ok the way I have it wired?? Or do I need to have a relay on there too???
-Ryan
-Ryan
I'm running a Blue in the stock location and wired to the stock electrical connector. It's worked fine for two years. Fuel pressure is always 8 WOT and 12 normal. Pressure only drops on cold mornings when the grids cycle and volts drop to 8 or 10.
I'm running my holley off of a 30 amp relay that is triggered by the stock lift pump harness.
Me too.
i am running a relay triggered off of the stock LP wire. This way the Holley gets full voltage from the battery, not what's left over from the stock LP hot wire.
AlCorr
114
02-11-2009 02:32 AM
Texaschevelle
26
11-16-2007 08:08 PM
AllonBlack
03-04-2007 12:52 PM
Tiger Rag
03-07-2006 06:56 PM
